Автор Тема: 21TV036  (Прочитано 203 раз)
21TV036
« : 03 Июля 2023, 13:01:07 »
GR1VH_AX 43 models:
• KD-43X85J
• KD-43X89J
Subject: Half Picture Solarization (AX43) [Revision 0]
Customer report half picture solarized when the TV is in cold condition. Issue should be gone as soon as the TV set reaches operation temperature. See example pictures below.
CAUSE
Certain affected panels cause this behaviour.
Do not replace any parts like mainboard, T-CON or FFC. The issue is strictly related to specific panels. Sony is working on a software solution to improve affected models. Until a software update is available resolving this issue the set will need to be exchanged (AEP or DOA depending on the situation).
