Автор Тема: 21TV035  (Прочитано 224 раз)
21TV035
« : 03 Июля 2023, 12:59:42 »
GR1VH_AG 75 models:
• XR-75X95J
GR1VH_AR 65/75 models:
• XR-75X94J, XR-75X93J, XR-75X92J, XR-75X90J,
• XR-65X94J, XR-65X93J, XR-65X92J, XR-65X90J
GR1VH_AX 65/75 models:
• KD-75X89J, KD-75X85J
• KD-65X89J, KD-65X85J
GN6VH_NX/NXB 75
• KE-75XH9005, FW-75BZ40H
Subject: Method to Confirm Whitish Symptom (AG 75, AX / AR 65/75, NX/NXB 75) [Revision 1]
Please refer below method to confirm Whitish symptom. Examples of NG:
Steps to identify Whitish Symptom 1. Get Color Pattern Files • Either download the zip file attached to this TB • Or download from this link 2. Copy them to a USB drive 3. Insert USB to TV Set 4. Open Media Player 5. Select Orange Pattern 6. Change the TV Picture Setting to ‘VIVID’ 7. Change Brightness to MAX. 8. Check Whitish Condition on orange pattern. 9. Select White (50%) Pattern 10. Check Whitish Condition on white pattern.
CAUSE
Panel defect.
Panel exchange is needed, so an AEP event is needed (end customer case) or DOA return (for dealer case).
