Автор Тема: 21TV028  (Прочитано 490 раз)
21TV028
« : 03 Июля 2023, 12:32:46 »
GR1TP chassis
Subject: How to change serial number / Panel ID (GR1TP chassis)
Serial number and Panel ID can be updated by following the below procedure.
1) Enter Service mode : in any source (TV/HDMI…etc), press 1 2 3 6 5 4 by remote control.
2) service mode will be displayed on the screen.
3) check the panel used in the set in order to know the correct 'ADC model' name. Check in the attached ' Panel_ID.xlsx ' file.
4) Unzip the attached ‘ TPVFactoryService.zip ‘. Change the ' SETTYPE ' and serial number in the ' TPVFactoryService.cookie ' file.
5) Save the corrected ' TPVFactoryService.cookie ' file in the root directory of a USB flash drive.
6) Insert USB flash drive into USB port while TV working in Service Mode.
7) Wait for system update from USB flash drive. The TV will prompt "Apply Cookie Done!“ when update
 KD-32W800 CEI_BOE NWK    KD-32W800 CEI   E32K92NBAKSNNZX   LVB320HBF5BSBB0H0X   BOE-F55-NWK   KD-32W800_1st
E32K92NBAKSN2ZX
KD-32W800 CEP_BOE-NWK    KD-32W800 CEP   E32K92NBAKS22ZX
KD-32W800 UKA_BOE NWK    KD-32W800 UKA   E32K92NBAKS32ZX
KD-32W804 CEI_BOE NWK   KD-32W804 CEI    E32K92NBAKS62ZX    LVB320HBF5BSBB0H0X   BOE-F55-NWK   KD-32W804_1st
KD-32W800 CEI_BOE NM3    KD-32W800 CEI   E32K92NBAKSY2ZX   LVB320HBF5BSBC0H0X   BOE-F55-NM3   KD-32W800_1st
KD-32W800 CEP_BOE-NM3    KD-32W800 CEP   E32K92NBAKS42ZX
KD-32W800 UKA_BOE NM3    KD-32W800 UKA   E32K92NBAKS52ZX
KD-32W804 CEI_BOE NM3   KD-32W804 CEI    E32K92NBAKS72ZX    LVB320HBF5BSBC0H0X   BOE-F55-NM3   KD-32W804_1st
KD-32W800 CEI_LGD    KD-32W800 CEI   E32K52NBAKSN2ZX   LVG320XYA8BSBE0H0X   LC320DXY-SMA8   KD-32W800_2nd
KD-32W800 CEP_LGD    KD-32W800 CEP   E32K52NBAKS22ZX
KD-32W800 UKA_LGD    KD-32W800 UKA   E32K52NBAKS32ZX
KD-32W804 CEI_LGD    KD-32W804 CEI   E32K52NBAKS42ZX   LVG320XYA8BSBE0H0X   LC320DXY-SMA8   KD-32W804_2nd
KD-32W800 CEI_LGD-D   KD-32W800 CEI    E32K52NBAKS52ZX   LVG320XYA8BSBE0H0X   LGD-SMA8    KD-32W800_2nd
KD-32W800 CEI_LGD SHAC-D   KD-32W800 CEI    E32L52NBAKS52ZX   LVG320XYACBSBH1H0X   LGD-SHAC    KD-32W800_3rd
         LVG320XYACBSBT1H0X
KD-32W800 CEI_LGD SHAC    KD-32W800 CEI    E32L52NBAKSN2ZX   LVG320XYACBSBH1H0X   LGD-SHAC    KD-32W800_3rd
         LVG320XYACBSBT1H0X
KD-32W800 CEP_LGD SHAC    KD-32W800 CEP    E32L52NBAKS22ZX   LVG320XYACBSBH1H0X   LGD-SHAC    KD-32W800_3rd
         LVG320XYACBSBT1H0X
KD-32W800 UKA_LGD SHAC    KD-32W800 UKA    E32L52NBAKS32ZX   LVG320XYACBSBH1H0X   LGD-SHAC    KD-32W800_3rd
         LVG320XYACBSBT1H0X
KD-32W804 CEI_LGD SHAC    KD-32W804 CEI    E32L52NBAKS42ZX   LVG320XYACBSBH1H0X   LGD-SHAC    KD-32W804_3rd
         LVG320XYACBSBT1H0X
21TV028 - How to change serial number  Panel ID (GR1TP chassis)
« Последнее редактирование: 07 Июля 2023, 14:33:05 от aze1959 »
