Автор Тема: 21TV023  (Прочитано 328 раз)
21TV023
« : 03 Июля 2023, 12:20:15 »
XR-xxX94J, xxX93J, xxX92J, xxX90J KD-xxX89J, xxX85J
Subject: T-con Board Replacement.
Different non-compatible T-con boards for the listed model have been registered for service.
CAUSE
Manufacturer change.
In case of any T-con board failure replace the T-con board according to the part number info below.
75”
AR Segment O-Cell AX Segment O-Cell ST7461D02-A (ver. 2.1) ST7461D02-H (ver. 2.1) ST7461D02-F (ver. 2.1) ST7461D02-A (ver. 2.5) ST7461D02-H (ver. 2.5) ST7461D02-F (ver. 2.5) 1-011-259-11 1-011-259-31 1-011-259-51 1-011-259-21 1-011-259-41 1-011-259-61 AR segment XR-75X9xJ
34291100BF0111 101126011 OK PROHIBITED PROHIBITED OK PROHIBITED PROHIBITED 34291100C60111 101126031 PROHIBITED OK PROHIBITED PROHIBITED OK PROHIBITED 34291100C40111 101126051 PROHIBITED PROHIBITED OK PROHIBITED PROHIBITED OK AX Segment KD-75X8xJ 34291100BF0A11 101126021 OK PROHIBITED PROHIBITED OK PROHIBITED PROHIBITED 34291100C60411 101126041 PROHIBITED OK PROHIBITED PROHIBITED OK PROHIBITED 34291100C40411 101126061 PROHIBITED PROHIBITED OK PROHIBITED PROHIBITED OK
65”
AR O-Cell AX O-Cell ST6451D03-5 (ver. 2.1) ST6451D03-8 (ver. 2.1) ST6451D03-5 (ver. 2.5) ST6451D03-8 (ver. 2.5) 1-011-257-11 1-011-257-31 1-011-257-21 1-011-257-41 AR segment XR-65X9xJ 34291100BG0111 101125811 OK PROHIBITED OK PROHIBITED 34291100C00111 101125831 PROHIBITED OK PROHIBITED OK AX Segment KD-65X8xJ 34291100BG0311 101125821 OK PROHIBITED OK PROHIBITED 34291100C00A11 101125841 PROHIBITED OK PROHIBITED O
55”
AR O-Cell AX O-Cell ST5461D11-2 (ver. 2.1) ST5461D11-3 (ver.2.2) ST5461D11-2 (ver. 2.2) ST5461D11-3 (ver. 2.1) 1-011-255-11 1-011-255-31 1-011-255-21 1-011-255-41 AR segment XR-55X9xJ 34291100930B21 101125611 OK PROHIBITED OK PROHIBITED 342911009C0811 101125631 PROHIBITED OK PROHIBITED OK AX Segment KD-55X8xJ 34291100930Q21 101125621 OK PROHIBITED OK PROHIBITED 342911009C0911 101125641 PROHIBITED OK PROHIBITED OK
IMPORTANT: When the T-Con board is replaced please apply the ‘ WB/Mura/CUC data transfer ‘ ( SoC to T-con ) like described in the Common Service Manual available in ASSIST. ( in ‘ Service mode ‘ select ‘’ Panel/PQ ‘’ - “ WB/Mura/CUC data transfer ”- )
