Автор Тема: 21TV022  (Прочитано 247 раз)
21TV022
« : 03 Июля 2023, 12:18:29 »
KD-49XF7596, 49XF70xx KD-49XE8396, 49XE80xx, 49XE70xx
FW-49XE8001
Subject: T-con Board Replacement [REVISION 1].
Different non-compatible T-con boards for the listed model have been registered for service.
CAUSE
Manufacturer change.
In case of any T-con board failure replace the T-con board according to the part number info below.
O-Cell SG O-Cell SN O-Cell LC490EQY-SMA2 LC490EQJ-SMA2 LC490EQY-SMA2 LC490EQJ-SMA2 LC490EQY-SMA1 LC490EQJ-SMA1 LC490EQY-SMA1 LC490EQJ-SMA1 T-Con *need to change Panel ID according to TV Set
1-001-520-11/21 1-001-520-31/41 1-001-516-11/21 1-001-516-31/41 KF 49” XE8396 XE8001 6871L-4922A 189711911 OK OK OK OK 6871L-5988C 100152121 PROHIBITED PROHIBITED PROHIBITED PROHIBITED KC 49” XE70xx 6871L-5135B 189713411 OK OK OK OK 6871L-5988C 100152121 PROHIBITED OK PROHIBITED OK CH /CHL 49” XF7596, XF70xx 6871L-5461C 189727412 OK OK OK OK 6871L-5988C 100152121 PROHIBITED OK PROHIBITED OK
