Автор Тема: 21TV020  (Прочитано 437 раз)
21TV020
« : 03 Июля 2023, 12:09:50 »
GN6UR, GN5UR, GN4UR chassis.
Subject: Service package GN6UR, GN5UR, GN4UR
SYMPTOM Issues
IRIS code
Section code Channel change stops working (OSD changes).
6264
SWA No sound from sound bar (eARC) after AC off/on.
I519
APD The time displayed in the screen is delayed when watching HDMI input.
F170
SWA After using TV for a period of time, Sound noise occurs. Fiber optic output is also noisy.
3540
APD 2 audios (App & TV) overlap at AC off/on in Pro Mode (B2B model only).
I575
APD
CAUSE
Software incompatibility.
Update the SoftWare to version PKG6.5066 EUA like explained in the ‘Software packages follow-up ’Technical Bulletin for your applicable chassis.
!!! NOTE: Do not use SW PKG6.5066EUA in combination with Conditional Access Modules (CAM). This will freeze the CAM App MMI.
Download the applicable file attached to this Technical Bulletin, unzip and copy the extracted file to the root of an empty USB stick.
Date
SW version
July 2021
sony_atvotafull_2018_1605066100_eua_auth.zip
PKG 6.5066
Sony DTV0FA70A0BA0AB 00004100 16050661000634
« Последнее редактирование: 07 Июля 2023, 14:28:39 от aze1959 »
