Автор Тема: 21TV019  (Прочитано 194 раз)
21TV019
« : 03 Июля 2023, 12:08:23 »
KD-50X8xJ, FW-50BZ30J Models.
Subject: Mura or uneven brightness prevention. TV set handling precautions.
Mura or uneven brightness can be seen at left side of TV screen during Turn ON condition.
CAUSE
After dis-assemble the TV set, optical sheet pop out can be seen due to
1) high force applied during Rear Cover assembly.
2) press on wrong area to close the rear cover.
1. Limit the force applied during assembling the Rear Cover.
2. On next page you can find the ‘Caution area’. The area on the rear cover where it is not allowable to push.
