Автор Тема: 21TV016  (Прочитано 334 раз)
21TV016
« : 03 Июля 2023, 12:04:36 »
KD-75X89J, 75X85J KD-65X89J, 65X85J KD-55X89J, 55X85J models
Subject: T-con Board Replacement. No display. [REVISION 1]
Different non-compatible T-con boards for the listed models have been registered for service.
CAUSE
Panel interface design change.
In case of any T-con board failure replace the T-con board according to the part number info below. Model P-Mod Suffix-A P-Mod Suffix-B P-Mod Suffix-C SONY Part No SONY Part No SONY Part No
AX55
O-Cell
Suffix -21
Suffix -41 N/A
T-Con
101125621
101125641 N/A
AX65
O-Cell
Suffix -21
Suffix -41 N/A
T-Con
101125821
101125841 N/A
AX75
O-Cell
Suffix -21
Suffix -41
Suffix -61
T-Con
101126021
101126041
101126061
Compatibility:
P-Mod Suffix-A: O-Cell suffix -21 ONLY compatible with T-Con suffix -21
P-Mod Suffix-B: O-Cell suffix -41 ONLY compatible with T-Con suffix -41
P-Mod Suffix-C: O-Cell suffix -61 ONLY compatible with T-Con suffix -61
