Автор Тема: 20TV026R0  (Прочитано 229 раз)
20TV026R0
« : 03 Июля 2023, 10:55:06 »
20TV026R0
KD-65XH9505, 55XH9505 models
Subject: T-con Board Replacement. No display
Different non-compatible T-con boards for the listed model have been registered for service.
CAUSE
T-con setting changed to support Source Driver IC.
!! If wrong combination assembled, it will cause ‘No Display’.
In case of any T-con board failure replace the T-con board according to the part number info below. Model Group 1 Group 2 SONY Part No SONY Part No SONY Part No
NH55
O-Cell
Suffix -11
Suffix -12
Suffix -13
T-Con
1-006-262-11
1-006-262-12
1-006-262-13
NH65
O-Cell
Suffix -11
Suffix -12
Suffix -13
T-Con
1-006-264-11
1-006-264-12
1-006-264-13
Compatibility:
Group 1: O-Cell suffix -11/-12 compatible with T-Con suffix -11/-12
Group 2: O-Cell suffix -13 ONLY compatible with T-Con suffix -13
« Последнее редактирование: 07 Декабря 2023, 08:39:35 от aze1959 »
