Автор Тема: 20TV024R0  (Прочитано 504 раз)
20TV024R0
« : 03 Июля 2023, 10:51:36 »
20TV024R0
GN6UR_NE Chassis
Subject: Support for PS5™ compatibility (4K120Hz signal format)
TV not compatible 4K120Hz signal format, used with PS5™
CAUSE
SoftWare incompatibility.
Update the SoftWare version with the PKG6.4775 (available in the below link) like explained in the ‘Software packages follow-up’ Technical Bulletin for your applicable chassis. ( 20TV005 )
Download the applicable file from the link mentioned in the below table, unzip and copy the extracted file to the root of an empty USB stick.
Date
Link
SW version
October 2020
sony_atvotafull_2018_1604775100_eua_auth.zip
PKG 6.4775
DTV0FA70A0BA0AB_00004100_16047751000616
« Последнее редактирование: 15 Февраля 2026, 10:17:43 от aze1959 »
