Автор Тема: 20TV014R0  (Прочитано 201 раз)
20TV014R0
« : 03 Июля 2023, 10:36:05 »
20TV014R0
KD-75XH92x, 90xx Models.
Subject: TV set handling precautions. Finger pinch prevention.
Set handling caution when TV set is unpacked and set up.
CAUSE
In order to produce an ultra-slim design the panel strength is not strong from construction point of view and need to be handled carefully.
Handle TV set carefully to prevent panel pinch.
1. Open the Top flap ① of the carton box, take out the Top cushion and lift up the Carton ②. Like illustrated in the below picture.
2. “Cell Protector ③“on the left/right side and “Cell Protector ④“ on the lower side are sticked on the panel to prevent panel pinch when handling.
Please don’t remove “Cell Protector ③ and ④“ from the set until the TV is set up or wall mounting is finished.
« Последнее редактирование: 07 Декабря 2023, 08:27:10 от aze1959 »
