Автор Тема: 20TV013R2  (Прочитано 1740 раз)
20TV013R2
« : 03 Июля 2023, 10:34:42 »
20TV013R2
KD-55AG8 model
Subject: 6 x LED blinking [REVISION 2]
1. 6 times Error LED blinking.
2. 6 times LED blinking at switch ON after long St-by period.
CAUSE
A. Compatibility issue between software and Power Supply Unit.
B. Poor connection between Main-board and T-Con board.
(ONLY for KD-55AG8)
Update the SoftWare version to PKG6.6575 (attached to this Technical Bulletin) or above like explained in Technical Bulletin (19TV012)
Download the applicable file attached to this Technical Bulletin, unzip and copy the extracted file to the root of an empty USB stick.
Date
SW version
October 2020
KD-43XG8305
KD-43XG8388
KD-43XG8399
KD-43XG8396
KD-49XG8305
KD-49XG8377
KD-49XG8388
KD-49XG8399
KD-49XG8396
KD-49XG9005
KD-55AG8
KD-65AG8
KD-43XG8096
KD-49XG8096
KD-55XG8096
KD-65XG8096
KD-75XG8096
KD-43XG8196
KD-49XG8196
KD-55XG8196
KD-65XG8196
KD-55XF8096
KD-49XF8096
KD-43XF8096
KD-65XF7596
KD-55XF7596
KD-49XF7596
KD-43XF7596
KD-65XF8505
KD-55XF8505
KD-49XF8505
KD-43XF8505
KD-70XF8305
KD-60XF8305
KD-65AF8
KD-55AF8
KD-75XF9005
KD-65XF9005
KD-55XF9005
KD-49XF9005
KD-65XF8577
KD-55XF8577
KD-49XF8577
KD-43XF8577
KD-65XF8588
KD-55XF8588
KD-49XF8588
KD-43XF8588
KD-65XF8599
KD-55XF8599
KD-49XF8599
KD-43XF8599
KD-85XF8596
KD-75XF8596
KD-65XF8596
KD-55XF8596
KD-49XF8596
KD-43XF8596
KDL-49WF804
KDL-43WF804
KDL-49WF805
KDL-43WF805
KD-65XF8796
KD-43XF8796
KD-55XF8796
KD-49XF8796
KD-65XD7505
KD-55XD7005
KD-49XD7005
KD-49XD8005
KD-49XD8305
KD-43XD8005
KD-43XD8305
KD-50SD8005
KD-65ZD9
KD-100ZD9
KD-49XD8077
KD-43XD8077
KD-49XD8088
KD-43XD8088
KD-49XD8099
KD-43XD8099
KD-65XD7504
KD-55XD7004
KD-49XD7004
KD-55XD8005
KD-75ZD9
KD-55XE8096
KD-49XE8005
KD-43XE8005
KD-75XE8596
KD-65XE8505
KD-55XE8505
KD-75XE9405
KD-65XE9305
KD-55XE9305
KD-75XE9005
KD-65XE9005
KD-55XE9005
KD-49XE9005
KD-43XE8077
KD-49XE8077
KD-49XE8088
KD-49XE8099
KD-49XE8096
KD-43XE8099
KD-43XE8096
KD-65XE8577
KD-65XE8588
KD-65XE8596
KD-55XE8577
KD-55XE8588
KD-55XE8599
KD-55XE8596
KD-77A1
KD-65A1
KD-55A1
KD-65XE8599
KD-49XE8004
KD-43XE8004
KD-55XE8396
KD-49XE8396
KD-43XE8396
sony_dtvota_2016_1606575100_eua_auth.zip
PKG 6.6575 EUA
DTV0FA60A0AA0AA_00004100_16065751000259
« Последнее редактирование: 15 Февраля 2026, 10:23:23 от aze1959 »
