Автор Тема: 20TV002R3  (Прочитано 221 раз)
20TV002R3
« : 03 Июля 2023, 10:14:08 »
20TV002R3
KD-55XG85xx, 55XG8796 models
Subject: No or intermittently no display [REVISION 3].
No or intermittent no display. Sound OK. White LED burning.
CAUSE
Bad connection between Main Board and T-Con board.
Refer to the diagnostic method like explained on the next page.
FFC connection (41P / 51P) failure or 41P connector on B board may be faulty. Perform a Tapping test to isolate the
problem.
Tapping test: Touch near the red frame – like indicated in the below picture – to change the symptom.
« Последнее редактирование: 07 Декабря 2023, 07:53:54 от aze1959 »
