Автор Тема: 543  (Прочитано 917 раз)
« : 21 Января 2015, 12:05:14 »
Model: KP-43HT20, KP-53HS20, KP-53HS30 No. 543
Subject: ABL Flicker in picture Date: August 3, 2001
Symptom:
(1185) ABL flicker may be seen in the picture on the models above when 16:9 enhanced
mode is turned on. The KP-61HS20 & KP-61HS30 were corrected before release.
Therefore no action is necessary on the 61-inch models.
Solution: To correct this flicker the procedure below should be followed:
