Автор Тема: 541  (Прочитано 964 раз)
« : 21 Января 2015, 12:04:26 »
Model: KV-32XBR400, KV-36XBR400 No. 541
Subject: New Bezel Is Available For Easier Speaker Grill
Replacement.
Date: July 6, 2001
Symptom:
(1161) The corner of the speaker grills may peel away from the front cabinet assembly. To
date, the only methods for replacement of the grills were to use a hot air gun to slowly
and gently remove the grills, or to replace the beznet assembly which requires
removal of the CRT.
Solution: If the customer complains about the speaker grill peeling away, the bezel portion of
the beznet assembly (including speaker grills) is now available as a separate part that
can be replaced without removing the CRT.
