Автор Тема: 523  (Прочитано 940 раз)
« : 21 Января 2015, 11:33:58 »
Model: KV-32XBR200, KV-36XBR200 No. 523
Subject: No Audio After Replacing G-Board; G-Board
Received From WRPC-AS May Not Be
Compatible In TV.
Date: February 2, 2001
Symptom:
(1510) G-boards received from WRPC-AS might not have the audio 5V regulator
components mounted. In this case, the TV will have no audio.
Solution: When ordering a G-board for the KV-32XBR200 or the KV-36XBR200 be sure to
also order the parts listed below! The solution depends on the 2-digit suffix of the
printed-wiring version silkscreened on one corner of the G-board received from
WRPC-AS.
For printed-wiring versions 1-671-380-21 and lower follow procedure # 1.
For printed-wiring versions 1-671-380-22 and higher follow procedure # 2.
