Автор Тема: 520R3  (Прочитано 832 раз)
520R3
« : 21 Января 2015, 11:30:37 »
Model: KV-36FS12, KV36FS13, KV-36FS16, KV-36FS17 No. 520R3
Subject: Transparent Bar In Picture Date: September 17, 2001
Symptom:
(1343) With a signal applied to the “S” Input of Video 1, while viewing a component signal
connected to the Video 4 input. A transparent bar that travels across the screen can
be seen.
Solution: If the customer should complain of the symptom above please implement the
following circuit change, on the UY Board.
Add two jumpers to the UY board. Use 24AWG insulated wires as follows:
1. D238 Anode to R1215 ground side.
2. D201 Anode to C1205 ground side.
