Автор Тема: 518  (Прочитано 886 раз)
« : 21 Января 2015, 11:24:19 »
Model: KV-27FV16 No. 518
Subject: SRS Mis-Operation Date: January 12, 2001
Symptom:
(117X) When the SRS is activated, and the set is turned off, one would expect SRS to be activated
when the set is turned back on. In reality, when the set is turned on the SRS is deactivated, but the customer
menu screen shows that the SRS is still activated, when it is not.
Solution: If the customer complains of the symptom above please replace the CPU IC001 on the MA
Board with version 3.1.
