Автор Тема: 513R1  (Прочитано 903 раз)
513R1
« : 21 Января 2015, 11:09:14 »
Model: KP-41T15, KP-41T25, KP-41T35, KP-46C36
KP-46S15, KP-46S17, KP-46S25, KP-46V25
KP-46V35, KP-48S35, KP-48V45, KP-53S15
KP-53S17, KP-53S25, KP-53S35, KP-53V25
KP-53V35, KP-53V45, KP-53XBR45
KP-53XBR4CT, KP-61S35, KP-61V25
KP-61V35, KP-61V45, KP-61XBR48
No. 513R1
Subject: CRT Replacement Date: August 21, 2001
Symptom:
(161X) Ground of replacement CRT may be different than the original. Heater resistor value
change may be required.
Solution: When replacing the CRT the following changes may be necessary.
1. When replacing the CRT the original may have used a braided wire across the CRT to ground the
CRT and CRT Board. The replacement CRT uses a grounding wire that connects to a ground lug.
This grounding lug wire should be packed in the replacement CRT box. See picture below.
