Автор Тема: 512  (Прочитано 835 раз)
« : 21 Января 2015, 11:08:19 »
Model: KP-57XBR10W, KP-65XBR10W No. 512
Subject: Intermittent retrace lines in picture Date: December 6, 2000
Symptom:
(5344) Retrace lines may appear when the set is first turned on from a cold start for about
one second.
Solution: If the customer should complain of this symptom please perform the following circuit
change on the CG Board.
Replace the resistor in the table below with the new resistor value on the
CG Board.
Change GCUT to 10 in the Service mode.
Readjust the following items: G-2 adjustment, White balance, and Sub-bright all in the
“Standard” picture mode.
