Автор Тема: 510  (Прочитано 908 раз)
« : 21 Января 2015, 11:01:58 »
Model: KP-53HS10, KP-61HS10 No. 510
Subject: Circuit change for white saturation Date: November 27, 2000
Symptom:
(1322) Saturation/low resolution is seen on the screen with high level white signal.
Saturation starts around 1.2vp-p of signal level on all Y, Pb, Pr inputs.
Solution: If the customer should complain of the symptom above the following resistor values
must be changed, on the conductor side of the “A” Board.
