Автор Тема: 504  (Прочитано 916 раз)
« : 15 Января 2012, 02:33:55 »
Model: KP-53HS10, KP-61HS10 No. 504
Subject: Audio Dropout/Distortion Under Low AC
Conditions.
Date: September 21, 2000
Symptom:
(2511) Audio mutes or distorts under low AC conditions
Solution: If the customer should complain of audio dropout please make the following circuit
changes on the “K” Board.
1. Change the value of capacitor C2054 to 10uf/ 50v.
Note: It is possible to use a 16v, or 25v rated capacitor as a substitute.
2. Mount a 10uf/50-volt capacitor from the anode side of diode D2023 with the
negative side of the cap to ground.
« Последнее редактирование: 21 Января 2015, 10:41:06 от aze1959 »
