Автор Тема: ASC20071025001  (Прочитано 852 раз)
ASC20071025001
« : 13 Ноября 2014, 15:15:03 »
DLP
MODEL: HLS5679WX
Chassis Constantine
SUBJECT: Intermittent shutdown / power cycling on - off. Common case is when using
component input or connecting a device to the component input.
DETAIL: Possible spikes in the current on the 6VB line or the 5V line from the SMPS PCB
can cause the unit to shutdown. The values of Capacitors CM860 and CS860 need to be
changed to correct this issue. See Figures 1 & 2 below.
