Автор Тема: ASC20070309001  (Прочитано 876 раз)
ASC20070309001
« : 13 Ноября 2014, 11:38:32 »
DLP
MODELS: HLS**86WX/XAA,
HLS**65WX/XAA,
HLS**66WX/XAA
HLS**87WX/XAA,
HLS**88WX/XAA,
HLS**76SX/XAA
Chassis Einstein, Lincoln,
Galilei & Iris
SUBJECT: DLP TV immediate shutdown within a few minutes / Ballast PCB change
BACKGROUND: DLP TV shuts off within 3 minutes because of defective ballast.
Problem Range: March 2006 ~ Feb. 2007 production
SERVICE PROCEDURE:
1. Power on DLP TV.
2. Check whether TV shuts off or not within 3 minutes.
3. If TV shuts off in 3 minutes, replace both Ballast and Lamp. See note below.
4. If TV doesn't shut off but the picture is dark, replace the Lamp only.
NOTE: The service parts code of the Ballast was changed from BP47-00033A to
BP47-00037A in JAN, 2007.
