Автор Тема: 2003-PJT-E010  (Прочитано 965 раз)
2003-PJT-E010
« : 30 Октября 2014, 15:27:09 »
 Model     :   L63A Chassis                           Bulletin Date   :   Aug. 01. 2003
 Buyer     :    Europe   ALL
 Subject  :   Replacing Toshiba lamp with Philips's in L63A Chassis
Background : Because of the license,The 3P LCD PJTV could not be made by use Toshiba Lamp any more
     When you needs to change the lamp of SVC in 3P LCD PJTV,
     you have to change Toshiba Lamp with Philips's
Material List for change
   It is necessary to prepare as following materials, If the lamp is changed.
      Parts name               Code            Description
   1-1   Assy Cover P-LAMP PLS100               BP96-00271B         ASSY PHILIPS LAMP 100W For 43", 50"
   2   Assy Cover S-Interface               BP94-00514A         The connector for each cable.
   3-1   LAMP-BALLAST               BP47-00008A         Philips Ballast 100W, for 43",50"
   3-2   LAMP-BALLAST               BP47-00009A         Phipips Ballast 120W for 61"
   4   LEAD CONNECTOR               BP39-00094A         The signal cable for Philips Lamp
   5   HOUSING-LAMP,MOUNT               BN61-00176A          Assy Lamp Holder
   6   HOLDER-BALLAST               BN61-00211A          The Fixed parts for Ballast
