Автор Тема: XBOX 360 Setup  (Прочитано 1267 раз)
XBOX 360 Setup
« : 26 Октября 2014, 12:45:19 »
Sharp LCD-TV’s work with the XBOX 360 using the component cable supplied with the XBOX 360 Premium Edition.
Depending on the LCD-TV that you are using, you may have to use the 3 RCA to 15-pin D- sub adapter cable supplied with the Sharp LCD-TV.
Please ensure you have the following equipment before starting:
3 RCA to 15-pin D-sub adapter (Supplied with Sharp LCD-TV)
HD AV Cable (Supplied with XBOX360 Premium Edition or can be purchased separately)
Remote control for LCD-TV XBOX 360
XBOX 360 controller
Sharp LCD TV’s can be configured to work with the XBOX 360 as follows:
