Автор Тема: LV-217  (Прочитано 956 раз)
LV-217
« : 26 Октября 2014, 11:44:28 »
LC-26P55E, LC-32P55E, LC-37P55E
LC-26P70E, LC-32P70E, LC-37P70E
LC-32GA8E, LC-37GA8E, LC-32BV8E, LC-37BV8E
LC-32GD8E, LC-37GD8E, LC-32BT8E, LC-37BT8E
LC-32GA9E, LC-37GA9E
LC-32GD9E, LC-37GD9E
LC-32RA1E, LC-37RA1E
LC-32RD1E, LC-37RD1E, LC-42RD1E
LC-26SA1E, LC-32SA1E, LC-37SA1E, LC-42SA1E
LC-32SV1E, LC-37SV1E
LC-26SD1E, LC-32SD1E, LC-37SD1E, LC-42SD1E
LC-32ST1E
General A defective crystal (X3001) has been experienced in the field. We inform you about the servicing
procedure against the failure as follows.
Symptom Picture breaks up. (Loss of synchronization)
Cause Defective crystal (X3001)
In some case, an unstable oscillation frequency from defective crystal (X3001) causes a
breakdown of a transformer (T7503) on the inverter unit.
Servicing In this case, please replace defective crystal (X3001) with new one.
If the inverter unit is also defective, please replace it with new one at the same time.
