Автор Тема: LV-163  (Прочитано 894 раз)
LV-163
« : 25 Октября 2014, 23:48:31 »
LC-37P50E
LC-37AF3M, LC-37AF3H,LC-37AF3X
LC-37AF3Z
General
A resistor was added on the inverter unit to improve the following phenomenon.
Phenomenon No power
(The lamp error is detected. The TV set can’t be turned on.)
Cause A deviation of the frequency setting starting up inverter
Servicing When you service any of the TV set with the above mentioned trouble or other some trouble,
please add a 1M ohms resistor (9JG0034016267) at the location of R7636 on the inverter unit.
