Автор Тема: LV-131  (Прочитано 815 раз)
LV-131
« : 25 Октября 2014, 23:40:30 »
General The main microprocessor software has been upgraded to version 1.02 with the following correction.
Model LC-20S4E
Details of
correction
Corrected program so that the COM BIAS value in adjustment process mode does not return to
initial value (125) after the main microprocessor software is upgraded.
Note: Even if the COM BIAS value returns to the initial value, there is no problem with the use of
the set at user.
Servicing When upgrading the main microprocessor software, please upgrade to the latest version 1.02 or
later.
For upgrade method, please refer to the service manual.
