Автор Тема: LCD 2012 01 01  (Прочитано 783 раз)
LCD 2012 01 01
« : 25 Октября 2014, 21:29:18 »
LCxxLE731EK LCxxLE810EK LCxxLE811EK LCxxLE820EK
LCxxLE821EK LCxxLE822EK LCxxLE831EK LCxxLE836EK
LCxxLE925EK
SYMPTOM When connected to external audio via ARC (HDMI) and viewing HD channels, noise is
heard from the external audio device.
CAUSE The external audio equipment is unable to decode audio format that is sent in
Bitstream (RAW) format.
ACTION You will need to set the unit to output audio in PCM format using the options below.
MENU, SETUP, OPTION, TERMINAL SETTING, DIGITAL AUDIO OUTPUT - PCM
