Автор Тема: LCD 2011 09 02  (Прочитано 849 раз)
LCD 2011 09 02
« : 25 Октября 2014, 21:26:42 »
LC40LE831E LC40LE833E
SYMPTOM Poor start operation when unit at very low room temperature < 1° C, LED blinks and
relay repeats on-off operation and the backlights remain off.
CAUSE On units produced before serial number 1060xxxxx the PSU may need to be modified
by the removal of D7302.
ACTION If you have a set where the above condition is reported, please check if D7302 is fitted
and remove if fitted. See Figure 1.
Please put a dot on the panel barcode label 1 to indicate this modification has been
completed as in Figure 2.
