Автор Тема: LCD 2010 08 01  (Прочитано 810 раз)
LCD 2010 08 01
« : 25 Октября 2014, 21:10:35 »
LC32DH500E LC32DH510E LC32FH510E
REASON There is a possibility of 2 different USB Switch ICs being fitted on the main pwb that
are not directly interchangeable.
ACTION If you locate the fault to IC8101 check to see what is fitted and order the correct one or
replace R395 to match the IC being fitted.
