Автор Тема: LCD 2010 06 04  (Прочитано 834 раз)
LCD 2010 06 04
« : 25 Октября 2014, 21:02:54 »
LC46LE700EA LC46LU700EA LC52LE700EA
REASON Additional new Power supply unit available.
ACTION If you need to replace the Power unit PWB you can use either the original part number
or this newer number as a replacement.
If there are any problems, the chart below lists the various possibilities of boards for
use within the model range.
