Автор Тема: LCD 2010 06 03  (Прочитано 793 раз)
LCD 2010 06 03
« : 25 Октября 2014, 21:02:18 »
LC40LE600EA LC40LE700EA LC40LU700EA
REASON New Power supply unit available.
ACTION If you need to replace the Power unit PWB you can use either the original part number
or this newer number as a replacement.
If there are any problems, the chart below lists the various possibilities of boards for
use within the model range.
