Автор Тема: LCD 2009 10 04  (Прочитано 806 раз)
LCD 2009 10 04
« : 25 Октября 2014, 20:17:49 »
LC52LE700E A
REASON Change of LCD panel and assembly parts from serial number 909011112.
ACTION If you require either a new LCD panel or assembly parts please check to see if later
panel is fitted see rear model label as in figure 1 and order the later “A” version parts if
required.
