Автор Тема: LCD 2009 09 02  (Прочитано 780 раз)
LCD 2009 09 02
« : 25 Октября 2014, 20:13:02 »
LC32D44EBK LC32D44EGY
SYMPTOM Shuts down due to lamp error (Power LED flashing).
CAUSE Either lamp or connector problem.
ACTION The following steps can be used to disable and reset the lamp protection circuit
allowing fault finding and checking, the part numbers for the lamps and connectors are
given below.
