Автор Тема: LCD 2009 06 02  (Прочитано 742 раз)
LCD 2009 06 02
« : 25 Октября 2014, 20:12:27 »
LC42DH77E
SYMPTOM Stuck in standby with fault indications of lamp errors.
CAUSE Lamp connector and Inverter PWB lamp contact track damaged.
ACTION Examine the Inverter PWB lamp contact points and each lamp connector for any
damage.
Replace all 18 connectors for the later type identified with a black dot (figure 3) and if
the inverter pwb track is damaged replace this as well.
Please identify any set where the connectors have been replaced with a black dot on
the rear model number identification label (figure 4).
