Автор Тема: LCD 2009 03 01  (Прочитано 739 раз)
LCD 2009 03 01
« : 25 Октября 2014, 19:29:38 »
LC26SB25E
SYMPTOM When the set is fitted to a VESA compatible wall bracket it has been found that there
is a possibility that there could be an isolation issue between the primary circuit and
the bracket fixings retained within the cabinet back.
CAUSE Exposed fixing point.
ACTION On units with a serial number before 811118526 please check to see if this modification
has been fitted, if not fit the isolation barrier sheet inside the cabinet back following the
instructions shown in the following pages.
If the unit is still under warranty, please refer to our LCD Television repair company
on UK 0870 787 4837 or Southern Ireland 01 843 4711.
