Автор Тема: LCD 2006 03 04  (Прочитано 801 раз)
LCD 2006 03 04
« : 24 Октября 2014, 22:36:02 »
LC26GA6E LC32GA6E LC37GA6E
SYMPTOM Various issues as follows:
• Unit powers down when the HDMI cable is connected.
• Unit powers down after 30 seconds of use.
• At initial switch on. If the unit is turned on again the backlight is turned on for one
second and switches off with lamp error.
• If the television has been working for one hour and is put into standby. It will not
start up again unless the mains lead is disconnected.
CAUSE Pinched or trapped cables.
ACTION Check the condition of the following cables
