Автор Тема: LCD 2005 10 04  (Прочитано 807 раз)
LCD 2005 10 04
« : 24 Октября 2014, 22:24:54 »
LC26P50E LC32P50E LC37P50E
SYMPTOM One of the following symptoms:
· Will not power on flashing Red LED, lamp error counter at 5 works ok when reset.
· Will not power on flashing Red LED, not able to enter any service mode.
CAUSE The fault is caused by a short circuit to ground inside the LCD panel where one off the
lamp cathode wires have been trapped and damaged, see pictures below.
Depending how badly the wire is damaged will determine if the fault is intermittent
(reoccurring) or permanent.
