Автор Тема: LCD 2005 05 04  (Прочитано 826 раз)
LCD 2005 05 04
« : 24 Октября 2014, 20:45:01 »
LC26GA3E LC26GA4E LC32GD1E LC32GA3E
LC32GA4E LC37GD1E LC37GA3E LC37GA4E
LC45GD1E
SYMPTOM Inside of the screen is dirty - a dark shadow is apparent across the screen or at the
bottom. This is more noticeable on a white screen. The dirt can not be removed by
cleaning the outside of the screen.
ACTION To remove the dirt and ensure that the likelihood of contamination entering the panel
again is reduced, carry out the following action. Note that each screen size requires
different repair process, depending upon the table below:
