Автор Тема: LCD 2005 04 02  (Прочитано 815 раз)
LCD 2005 04 02
« : 24 Октября 2014, 20:42:08 »
LC37GD1E LC37GA3E LC37GA4E LC32GA3E
LC32GA4E LC26GA3E LC26GA4E
REASON There has been a printing error in the PC compatibility chart. These models are not
compatible with 1366 x 768 resolution, when using a digital signal. This information
was not included in the Appendix of the operation manual.
ACTION If a complaint is received, explain that the compatibility is as per the table below.
Note that the 1366 x 768 resolution is only applicable to the analogue signal input.
