Автор Тема: 12-TV-N068 817  (Прочитано 775 раз)
12-TV-N068 817
« : 17 Августа 2015, 16:09:12 »
817 Writer Sungil Kim
Category Other devices
Midcategory
Component doesn't work.
Subcategory
Cable (A/V, Component)
Model Name EH6350,6450 Series
Specific
Symptom
Component Ident is able, but "There is no input signal"
appears. When OSD external In is connected, it is
recognized as Component.
Cause
Right side of CN502 Pin Jack arises, so soldering is
missing. Pin arises from the right Indent area.
How to
Inspect &
Handle
Check visually as the following picture. If right side
arises, perform re-soldering or replace the Main board
